Have been playing and would like some feed back on a simple Lockup Circuit with panic brake overide.
Circuit uses 3 cheap car type change over relays.
Simple idea that relays 1 & 2 latch to engage lockup and in the case of panic or wanting to remove lockup simply touch the brake pedal.
Most of the time when trundleing along you only need to back off to slow down and not brake every 20 yards.... some muppets do mind, followed a few in my time.
Suppose descent control with it on is not possible due to the brake off function but more use when pulling up hill and you want it to lock lower down the revs.
