can anyone please give me a bit of giudence please,im going to fit a tow bar to my 3.oltr 95 mreg surf kzn ssrx is the model,im not good at all with electrics so could anyone please give me any instructions on how to do the electrical side of the job.thanks.
electrics for tow bar
tow bar electrics
thanks for the replies,ive decided to get it fitted by a proffesional bit too much for me.my brother has a surf also and would fit it for me but works away so he doesent have time the thing he told me was that there is a socket behind one of the light clusters that the wires conect to so you dont have to run them through the car,,,,dont know if this is correct any one know if its right? again thanks for your replies allways helpfull
elvis
dead right, behind each of the rear light clusters is a multiplug with all the wires you will need, just look at where they are in the connector block and that should be fine.
Only thing is that you will need to run a seperate wire across to the other side for that indicator (I ran mine under the boot trim panel). My socket came pre wired and only took about half an hour, including bolting the socket plate to the towball
hope this helps
hawaiiI'm not overweight, I'm undertall!
