I have just got my first surf a 91 2.4 ln130 and the ac does not work. The compressor is free but the electronic clutch does not engage. I cant seem to find a fuse or relay for the ac. Has any one got any ideas
surf air con
Have you checked the gas level? I believe these have a low pressure/level cut off which will stop the air con working if the level is low.
I am sure someone will know more than me about this but i believe there is a sight glass somewhere that you can check the levels?
						[IMG]http://www.yotasurf-online.co.uk/public/coppermine/albums/userpics/10024/surf3.jpg[/IMG]
Big 'n' beautiful!
Big 'n' beautiful!
Regas and sniff test needed .Originally posted by tony exall
A regas will charge up the system and then a 'sniffer' will find a leak if there is one .
Make sure the correct gas is used , possible R12 or a supercedding one will be used on imports , but someone else may confirm that one .
Low gas will cause the low pressure switch to not engage the compressor clutch to prevent damage to the compressor .
RickRick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Air con specialist
Try Reader Air Conditioning, Unit 1, Boundary Business Centre, Boundary Way, Woking.
Tel. 01483 726300
www.readerair.co.uk
They seem very knowledgable and, in my experience, are pleasant to deal with.Keith
Try behind glove box for a/c fuse!!Originally posted by tony exall
 I have just got my first surf a 91 2.4 ln130 and the ac does not work. The compressor is free but the electronic clutch does not engage. I cant seem to find a fuse or relay for the ac. Has any one got any ideaswww.europa88.co.uk Loadsa mods!
