If I remember correctly the dash ilumination is on the same fuse as the side lights, whereas the front headlights are on a seperate fuse. So if your sidelights aren't working I'd start with the fuses.
Your tail lights are also on the sidelight fuse, so it's worth checking sooner than latter.
Sorry i think i should of explained abit better then i actually did. Its not the dash illlumination lights that have gone out its the Oil,T-belt,Battery etc etc lights that have all gone out at once.
I've checked all the fuse's and they are fine. What i have noticed though there used to be a "beeeeeeeeeeeeeeeeeeep" after i left the ignition on for a few seconds, well that dosnt happen any more.
This could be completely wrong, but I think I've read sometime in the past, that a faulty alternator can cause problems with those lights. Might be worth checking the output across the battery terminals.
