sunroof not working
  • sunroof not working
    hi any one help my sun roof is not working .
    i can hear the moter but the roof stays shut.
    thanks
    thanks
    open the little flap beside the roof switch and inside you will see the slot for a screwdriver to fit to manually open or close the roof. if you turn it and nothing happens, the cable will probably be broken. if you can move it with the screwdriver, the drive gear on the motor is either loose or the teeth have sheared off. either way fairly big bucks. good luck!
    jim.b.
    1990 SSR LTD 2LTE auto
    1985 SR V8 4.4 litre manual
      thanks
      Steveo.
      If you need parts for it Bob (Hilux) on this forum has a complete sunroof assembly put aside for me (hopefully he has still got it as it has been a while and I've not been able to pick it up yet because of various things).
      I only need the Glass so we could maybe work something out.
      I know Feltham pretty well as I used to live in Ashford Common.
        Sunroof
        YES Andy l still have the Sun roof put to one side for you l will not sell it untill you say you don't want it.
        Live Life To The Full
          Bob.
          You're a star. It will be in the next couple of weeks (promise). I've got to go and see my mum, I think she probably won't recognise me now anyway.
            Sunroof
            Have Got A Spare Sunroof Motor Left Over As Well.
