Tonight i decided to try and find out what is wrong with the spot lights on my 91 SSR-X. They have never worked since i got it. I checked the bulbs and they appear to be ok. So i thought i would check the wiring. The wiring looks like it is a factory fitted loom joining with the main loom behind the offside battery. I have checked for voltage across the plug into the back of one of the lights and with all lights on (main beam and fog) there is no voltage present. I have not checked the loom for an earth fault yet though.
I have looked for additional fuses around the engine bay and under the drivers side dash but cannot find any.
Does anybody know whether a factory fitted spot light loom was an option? And if so, are there any fuses or relays anywhere that i can check. I cannot find any mention of the loom in the diagrams in the Max Ellery manual i have.
Thanks.
EDIT:
I have searched this forum. Whilst there is loads of good info on fitting spot lights and the wiring required, there is nothing (i can find) about a factory fitted option.
Thanks.
EDIT:
 I'll look tomorrow.
