not alternator!!!!
  • not alternator!!!!
    Well,the A********r has been on a bench all day and been given a clean billof health. Placed back under bonnit and,true to form, icon lights back on and the high pitch warning sound is back (along with husbands tears) any ideas please.
    Sad Su
    Hmmmm, check the battery voltage at the terminals it should be around 12.8 volts without the engine running.
    Check it with the engine running and it should be higher 13.4 volts upwards. This will confirm that it is actually charging via the loom or not.
    If it doesn't get higher then assuming your bench test is good then check the loom. edit - especially the earth strap to the engine
    I suspect that it is a problem with the indicator ciruit and that it is charging the battery. I notice on the circuit diagram that there is a fuse for the charging indicator so check this http://www.afm15.dial.pipex.com/surf...torpreheat.jpg
    If this doesn't solve the problem then check the grounds to the chassis for the instrument cluster.
    Hope this helps
    Rich.
    Sad Su
      I had exactly the same symptoms on my 2.4.$540.00 and a new alternator problem was fixed.Have someone else check the alternator.
      Neville
        alternator
        Thanks for the tips. Hubbie outside testing it now. But not looking good. Everytime we turn the key the dash lights up like a christmas tree, and the worning sound is deafing.
        Su & Reg
        PS do you know a biking thatcher who lives in Kings Clere?
          Is this slang????? hehe
          Nope don't think I know any motorcyclists who are mad enough to climb on the roof with a load of reed. Know plenty of mad motorcyclists just not thatchers.
          Oh and I only know one person in Kingsclere!
          Hope hubbie had some luck.
          Rich.
            New alternator has arrived today and will be fitted tonight. Hopefully this will resolve the problems.
            Su & Reg
              Guess what. The bench lied! 1 new alternator later and the car is now going, which is lucky as its sooooo wet in Sussex. Many thanks for all your tips.
              Reg & Su
                Good news, back on the road, back grinning
                  Good to hear you're mobile again
                  Roger
