Hi All, looking for advice,
My 91 2.4 wouldn't start yesterday it had been driven 10 mins before fine (1 mile) and lots recently towing a caravan on holiday and I thought the battery charge was too low due to accessories while we were away, it turned over very slowly for a couple of seconds then gave up, I tried jump starting off another car but only got the same result. I took the battery out charged it over night and put it back in, still the same. Took the battery to the shop they said it still had over 800 crank amps (which I thought was good after 2.5 years and starting new with 850 on the label) put it back in and looked for any loose wires or earths or similar but found nothing wrong. Then suddenly it works again and leeps in to life as you would expect with 800 CCA. I'm thinking a loose wire? but does anyone know any likely connections?
Or could this be starter contacts which lots of threads seem to point to (even though it didn't just click it just didn't turn fast enough or for long enough)
Thanks in advance
Darren
Thanks in advance
Darren
