PLEASE HELP - Electrical fault
    i take it you have checked the earth connections to the body?
    SWIFT AND BOLD
      Chassis. I'd go with Charvell's suggestion initially and check all of the earth bonding straps. They can be the cause of unusual problems if any of them are making poor contact, and there are only several to check.
        With respect "The garage has now sid that its a wiring fault and not worth fixing" doesn't sound like a 'Specialist' to me.
        i agree,to me thats the "oh ollocks we cant find the fault,pass the buck"answer
          May sound daft - blocked fuel filter causing starvation??
            hi matey, wifey had a similar problem on her "cough cough" Pajero.
            They're prone to it an on there it was caused by air getting into the fuel pump past an 'O' ring on a shaft that gets worn. cost £400 to have it put right but its been ok since then.
            Hers started to do it occasionally but as time wore on it got more an more frequent until it happened on a daily basis.
            Keep your friends close and a hammer closer
