Hi All,
('95 3.0TD 4Runner)
Not very good when it comes to car electrics, but I have recently discovered two problems. My rear fog light doesn't work, and the switch in the cab to raise and lower the rear window has stopped working too. I have done some research and the window and fog switch appear to be ok (using a meter), and I also appear to have about 10v across the fog light contacts, but no light. I did read some information about the relays behind the near side rear lights, and that it might be wiring, but is that likely is I'm getting a reading? The window works ok with the key though.
Any thoughts, abuse etc.. all appreciated.
('95 3.0TD 4Runner)
