Hello
  • Hello
    I have recently bought a Hilux Surf SSR-X, model 1997, turbo-intercooler.
    The light for the glow plugs goes off after a second or two, the start up is a bit prolonged. CAN WE ADJUST THE TIMER FOR THE GLOW PLUGS? HOW?
    chakrala
    Hi n Welcome, ya glowplug light sounds about right.. sounds like ya could do with some new Glowplugs !!
    Not sure about altering the glowplug timing...
    Do a search as somebody recently asked the same Q !!
    Hope this helps...
    There's always a Payback .... Just don't expect a Warning !!!!
    Buncefield Burner
      The light is just an indicator that the system is operating. The timer is ECU controlled depending on engine temperature. Leave key in on position untill you hear a clunk from the glow plug relay then try to start. If you leave the key on a little longer you should hear a beep. Check glow plug voltage. It should be around 10.5V and then drop to around 6.5 after a few seconds. No voltage may be blown fuse. Glow plugs are best tested for resistance individually and should be less than 1 Ohm.
        welcome to the forum mate
        One day at the time I guess..
          nev's spot on, I find on really cold mornings that after light goes out (about 3 seconds) that if I leave it until I hear the relay click it fires up easily after a couple of turns of the starter.
          Alan
            thanks for replies
            I dont have user's manual for my surf; can any friend guide me how to get one?
            Can u show me how/when to use 4X4?
            chakrala
              http://forums.bauchan.org/portal/downloads.php
