Right, I have done a search and I’m sure this has been mentioned before.
To charge the batteries, if you have the two battery version (KZN185) do you just connect the battery charger to the positive on one battery and the negative on the other, or do you charge each one individually, if that’s the case do the batteries have to be disconnected.
