Right lads I am slightly at a loss here. I was having problems with my Surf constantly running the batteries flat so took it for a battery check at Kwik Fit as I had read all the battery stuff on here but was still unsure as to what the problem might be.
I assumed it would be all the short journey's I do and not getting a good charge back into the batteries. Kwik Fit informed me that one of my batteries was goosed but that the alternator was putting a charge back in so they recommended new batteries.
I duly took this advice and bought 2 batteries recommended with more than enough power to do the job 650CCA for each battery.
I have had the batteries fitted for approx 3 weeks and now I have what appears to be the same problem with running flat.
I know its not the batteries obviously so what is my next port of call? Is it likely that the little short journey's approx 5 mins in the morning to work and 5 back is just draining the batteries in rapid fashion ?
Or is t likely to be an alternator problem ? Are there any checks I do myself that would paint a clearer picture? Would it be a good idea to get it checked out for any drain outwith normal parameters?
thanks
thanks
