I was driving the other night on highbeam with my rooflights on as well
when all the lights went out except the side lights.
The 2 10amp headlamp fuses had blown.
When I changed the fuses one of the headlamps would not work, so I changed the bulb and it seems the original bulbs were uprated ones 80/100watt ones.
If I run these uprated bulbs should I uprate the fuses to 15amp?
would these bulbs running for a while blow the 10amp fuses?
