Hi can anyone help me!!! I have a 1990 2.4td hilux,Manual. I have a near complete electrical failure. only battery light comes on. The car wont start and,although I can link out direct from battery to S.Motor to get it running,the lights work and that is about it!!. No display lights on dash,no indicators,fan, Wipers ETC....... I have checked all fuses under bonnet and under dash...OK Checked operation of all Relays and there contacts...OK. removed ignition barrel and if I link across two terminals with the ignition off then I can get the previously mentioned items to work but as soon as I turn it on there is a dimming of the lights and a surge of current. There is nothing wrong,as far as I can see, with the igni barrel. IT all happened so suddenly. pulled up turned her off. 20 minutes later turned her on and nothing. HELP MUCH APPRECIATED!!!!......TA
