I have a small problem that i am at a loss with at the mo.
I went to start the truck after a few days of not using it and it would not start, the wifey said it was cause i had not used it for so long so i jumped it and checked the op of the alternator all ok , went out and got some stuff then came home no problems, thoght about when i had used it last and it was only a few days, so i put it down to a one off but the following day same thing wont start, tried it and just a slow crank over , the next day dead as a door nail.
now i know you will all say that the batteries are shot but i put a new pair in not 5 months ago, so i reckon that something is draining them, any one had this yet? also as a coincedence the aerial no longer works so i took the supply fuse out after the first jump start just incase it was draining the bats?
