I know and I apologise in advance, i have searched for a solution but can not find one, My rear window is not doing anything, I have stripped off the cover to reveal the motor and wires, I have jammed the switch, and when i put my multi meter on it, there is no reading. If any one can shed some light on this I would be very very happy, or perhaps come and help fix it in return for some beers
Rear Window
Originally posted by ABE View Postis it the same beep if the tailgate isn't closed properly?
Check the locks either side of the tailgate because if it isn't closing right then it wont send power to the motor. It will just beep.
Originally posted by hiroler View PostCheck the rear wiper is in the off position and give it a waggle might not be seated properly!
Muchly appreciated
Ed
Originally posted by edcase081 View PostI'm sure the wiper works, thing is, I will shortly be getting this on the road, I want to be able to use the back door for the dogs, shopping etc... is there a generic problem for this sort of thing? I can't seem to find a solution, all of the ones you guys have shown, it hasn't fixed it, cheers so far guys
Muchly appreciated
EdMy other cars a QUAD
(sv1000spilot on surf forums)
THe window will come down any time from the switch as long as the ign is on and the key opperates it when ign is off obviously! the only time it does not opperate is when the door is not closed properly you get a beeping noise or the wiper is not seated properly. the wiper works with the window up but it might not be going to the return position.
