Hi ,10 days into owning my first Surf ('91 2.4td) ,i cant work out the rear wiper. When i got the surf the rear wiper was in its little locator at the top ,so the rear window can be lowered.When turning on the rear wiper nothing happened in ethier posistion intermitant or full ,but if left in full postion it will do one single wipe then return-only when i start the engine ,after that it does nothing. So i forced the wiper arm to the other side of the wiping arc ,now the wiper wipes happily all day long in both full or intermitant postion. But it does not return to the little locator position ,so when opening the rear window i have to get out and force the wiper arm up and into postion. What is it meant to do ,do they return to locator after every wipe or when switched off ,or do you have to manually locate the wiper every time before you open rear window?
A little perplexed
A little perplexed
