Hi all,
i need some technical advice, i have a keyless entry system with a boot release function, and want to modify this function to act as a remote starter.
The way i remember it is that there are two wires which need to be contacted for the ignition to be on, then one which needs to be contacted for 5 secs or so to start the engine.
Can this be done using a combination of relays? i.e, a timer one for the engine start and an on/off one for the ignition. If i then link these relays to activate when the boot release pulses will it work?
has anybody tried this before?
