My electric windows saga continues, I have resistence tested every wire on the drivers door all test ok at .8 ohms all the wires going into the rear doors all test ok, loom from rear drivers door back to the relay / fuse box panel in drivers footwell tests ok.
Firstly, is there a seperate relay or controller for the rear windows hidden somewhere in the rear of the truck?
Does anyone have a full on wiring diagram for the electric window system for the 1992 surf 2.4?
