Remote Tailgate Window
  • Remote Tailgate Window
    HI ALL LOOKING AT GETTING ONE OF THESE
    http://www.maplin.co.uk/Module.aspx?...6972&criteria=
    TO ALLOW ME TO OPEN AND CLOSE REAR WINDOW REMOTLEY AM I CORRECT IN SAYING THIS SHOULD WORK
    NOT TO SURE HOW I WOULD WIRE IM ASSUMING TO EITHER SIDE OF THE KEY SWITCH AND TO A PERMINATE LIVE FEED
    AND ADVICE APPRICIATED
    THANKS IN ADVANCE
    JON
    Wont work it runs on 240v. Its for a garage door.
      Transmitter battery: 23A (supplied - replacement JG91Y)
      Operating frequency: 433.92MHz
      Receiver supply voltage: 12Vdc
      Receiver current: 6mA (standby), 66mA (switching)
      Two relay outputs rated at: 12A peak / 5A continuous @ 230Vac
      I WAS LOOKING AT THE RECEIVER VOLTAGE 12Vdc IS THIS NOT NORMAL 12V
      IF NOT IF I FIND A 2 CHANNEL (1 FOR UP 1 FOR DOWN ?) 12V VERSION
      http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=002
      WILL IT WORK ANY IDEAS ON FITTING
      THANKS JON
        Yes this can be used on the surf as it is powered by 12volt dc. the only problem you may have are:-
        The contacts are ac rated and not DC,
        The relays switch momentarily when the transmitter button is pressed, you may find that the window will start to come down then stop until you take your finger off, then press again and keep going like this, or if you press the button the relay may stay energized untill you release your finger.
        Untill you try it you will not know for sure.
        Roy
        When ya stop having fun, Ya start getting old
          Sorry my mistake it runs upto 230v not only 230v
            Have a look at this http://www.maplin.co.uk/module.aspx?...48559&doy=21m4
            Yours seems to have a dodgy caps lock button...
              Looks like it'll work. The switching supply is 12vdc, exactly what you've got. The relays are rated for 2.7kw at 230vac. That's more than enough to power a window up & down. The spec also says it's switchable between momentary & on/off, sounds like a good gadget!
              You could take a seperate supply for the window but I would be inclined to loop the relay across the existing power supply i.e. think of the relay as a switch, you're just connecting another switch into the existing circuit.
              Hope this is clear to you. If it is maybe you could explain it to me
                Remember that the rear window is switched negative, to get round this I ended up using relays to convert the switched live from the remote unit into switched negative for the window relay.
                This is however an extremly useful mod.
                Gone from 4x4 to 1x2
                  The only problem with the on/off setting is that the relay will be permanantly energized up or down unless there is a timer on it to shut it off after, say 30 seconds. this may then conflict with the manual switch in the cab or the rear window key.
                  Roy
                    hi maverick
                    i dont suppose you could tell me hat you used and how you did it maybe a wiring diagram if poss
                    thanks in advance
                      This is the control unit I got (although it wasn't that expensive two years ago)
                      http://cgi.ebay.co.uk/Universal-Remo...2em118Q2el1247
                      To be honest with you I can't remember how I wired the relays to convert positve switched to negative switched, and they are now buried behind panels and loads of wiring. To make it worse I didn't write anything down just made it up until it worked!!!! I think if you put negative into the positive input and ground, switched live into the switched input, you end up with switched negative on the switched output.
                      I also wired direct to the rear window relay, using Codlords guide.
                      http://www.showmesome.info/hilux/wor...dow_switch.htm
                        I believe that this thread has details of how to convert positive to negative switching, unfortunatley I'm at work so don't know if the lack of pictures is due to the silly firewall they have.
                        http://www.hiluxsurf.co.uk/forums/sh...remote+locking
                          The firewall is innocent, the pics have gone walkies
                            I bought an alarm from http://stores.ebay.co.uk/durham-parking-sensors
                            This has a wire for winding windows up and a wire for unlocking a boot. With some timers and relays this could be modified quite easily to use the boot opening wire to wind the window down and then wind it back up by rearming the alarm. The power window function only has one output wire and would need to turn the ignition on and operate five switches to wind all the windows up, but could be used to wind up the boot window quite easily with a relay. It runs for 25 seconds which should be enough. The boot opening function would need a timer as that only operates quickly designed for central locking. RS components do 12 volt relay timers for about £30 but there may be cheaper less elaborate ones available. If the system is wired to the keyswitch then the ignition would not be needed.
                            There are loads of features on it too including a remote start although I don't think it would work on a diesel as I don't see how it waits for the glow plugs. I've not connected the remote start relays up, but might have a go at the remote start and rear window switch. The central locking is working. There is an immobiliser too which I've not yet connected. It's supposed to be connected to the starter, but the starter is easy to hotwire. I was thinking of breaking the gearbox selector wires so it can be started but would not go into gear, what theif would try to get around that by pulling wires out and shorting them?
                            It was 25.98 plus 7.99 p&p.
                              Following up from this I've written an article on how to do the installation and a few different methods....
                              https://hiluxsurf.co.uk/forum/modifi...-surf-4runners
                              Rob Watson (forum owner and admin)
