I have a 94 Surf SSR-G ,5 spd manual,3.0 TD.When i disconnect the speedo,it idles extremely low only after driving a few k's.Does anyone know why this is,and how to fix it? (APART FROM RECONECTING THE SPEEDO).Cheers,Karl.
Speedo/ idle issue
This vehicle is a dedicated OFF ROAD ONLY vehicle.This is why it does not run a speedo.In fact,it has no dash at all.I plugged an instrument cluster into the wiring via the original loom and the idle issue went away.But,the way the interrior is set up,i cannot leave this in when i use the vehicle.Hope this is ok by you Nev.
