I have a 92 2.4 Surf (and very nice it is too) but I'm getting intermittent starting problems that are completely independent of weather, temperature, time since last use.
Essentially, when I jump in and go to start, it sounds like the starter motor is turning - basically a whirring noise which starts to grind if I try a little to long.
Can happen after a short pitstop on a long journey, after leaving it for a day or two or even five minutes after a failed start!
Presumably some sort of starter motor problem???
