Took the spotlights off the other day to fabricate a bracket to fit 4 spots to replace the 2, i had noticed before that when the high beam is on (stick pushed back) then the spot lights come on but when i flash (stick forward) then it seemed brighter, didn't take much notice of it at untill spot lights had been removed, then (found this out on the way home from work, at night) when i pull the lighting stick forward i get main beam, as you would expect but when i push the stick forward for continiouse high beam i loose all lights (not good.!!!) push it back to middle ant the lights come back.
I have had a look on the wiring diagram but cant see how it has been split, as it seems to be only one cable to do both, flash and continiouse ie high beam. any idea wher to start looking, cant see any dodgy wiring under the steering wheel but haven't looked to hard.
Also do i need to have the spot lights switched seperaterly from the dip and high beam lights for the MOT, it is a job i am going to do but just wondering if it was a requirement.
