Liesure Battery, is it on the right or left hand side as you look into the engine bay from the front?
I assume the liesure battery is on the left and the starting battery on the right as the starter lead comes from that one.
I know I'm sort of answering my own question but confirmation of what I assume would be appreciated.
Oh and before anyone jumps on the 'use the search function' I did ......... try typing battery, or liesure battery, in and see how many results you get (and still none of them tell you which side it's on).
 although you wer'nt looking to fit a leisure battery the aus link is usefull in as much as it provides ya with a self jump starting back up as well as any leisure needs, (power wise) but if you dont have a fridge,camping stuff etc it aint worth the trouble, the two batterys you already have act as one biggun for cranking power and you can connect assessorys to either of em, do you suspect one of em then? thought you had newones, it's prob the starter fooked thats draining ya batterys, pulling to much amps,?
