Hey Gang, Ive been checking in all weekend as I reasemble my 2.4 TD.
I bought this unit with the engine in the back. Have had the short block done and Have succeeded ( hopefully) in getting it back into the truck.
I will be working on some brackets and wiring tommorow. I found this post on the site and need to know if his description is accurate, As I never took this truck apart and dont have one to look at for reference. The book i am using is weak, ( am downloading a manual from a link on this site, AWESOME!!!)
""I'm following this post as I have a similar problem - but I am confused.
My glow plugs do not work and there's a warning light on the dash which says there's a short circuit. I have just now checked to see if I've wired it up wrong but I don't see that I have (remember I changed the engine last month). The top part (on the inlet manifold) has blue insulator, metal strip to glow plugs, black coutersunk insulator, washer then nut; The lover one (on the underside of the inlet manifold) has raised insulator, wire with large hole, insulator with integrated washer, wire with small hole and nut.""
In the box of bits there is a black rubber with a metal cap and a small hole thru it IS IT realted to the under side wiring for the plugs?
If ANYONE has pics of things like the power steering pump in place or the alterantor or such That would help a load.
I have a couple of Black brackets that I dont recognize at all, ( they have a couple of diaginal holes at one end then 'V" out and bend and have slotted hook type bolt openings.
Sorry that is a lot.
Whatever anyone can offer will be greatly appreciated
Thanks Brad
Thanks Brad
