I'm just trying to work through a central locking problem. The solenoid in the drivers door isnt working. Ive stripped the solenoid from the door hopeing the solenoid was faulty for an easy ish fix and wishing it was'nt due to cost! The solenoid unfortunately works (or fortunately) when tested from a direct feed so I can only assume there is a fault in the wireing. Has any one else come across this fault before? where might the problem be?
Thanks guy's
Andy
					Thanks guy's
Andy
 so I can clean it again [/center]
