I have manage to fudge my way through it and have fitted one of those remote central locking kits off feebay, and I even got it to work!
But.....I am having trouble trying to get the sidelights to flash with it, basically I cant find the right wire to tap into.
Am I right in thinking that the eletrical circuits are negative switched?
With my bulb tester with a the croc clip to a body earth, if I probe about under the steering column I can cause the sidelights to come on without actually switching the switch, effectively shorting to earth, but if I connect the wire from the RCL unit to this wire then nothing happens, so I am thinking I have to tap into the negative side. The RCL is giving out +12v BTW.
So what wire do I need to find?
TIA
TIA
