I've recently looked at the door sensor that i need, as the plastic peice on mine has broken off, so there's no pressure on the switch to enable to read that the doors open, and in turn-the interior wont light up when drivers door is open.
Upon closer inspection, i removed the metal peice that the plastic pressure switch sits inside, and the wire has fallen back into the metal door framing
Is there any way i can put anything inside to retreive this peice? thought of a coat hanger, or bendy wire of some sort... maybe a magnet of some sort??
Help appreciated!!
Joe.
(I managed to get the door sensor switch peice i need from 'supersurf', so just need to get the alocated wire from the door frame to fit it all)
Help appreciated!!
Joe.
