Hey guys, I'm new on here!
Just got a question to do with my Clean-Ace air cleaner on my Hilux.
Basically, none of the lights were working on the system, so i removed it to find that the earthing wire wasn't connected-so i replaced the earth to where it was supposed to go.
On re-fitting the system, i've also found that the fan system to clean the air isn't working. I used a battery strait to the fan wires, diverting the circuit, and the fan works, but it doesn't work when all connected up. None of the solders, capacitors and fuse' are broken, so i can assume that the circuit is broken or loose, somewhere inside the system?
If anyone has one of these systems, or knows anything about why it isn't working, i'd greatly appreciate the input.
Thanks guys,
Joe.
Thanks guys,
Joe.
