Hey guys,
I'm busy wiring in a Sony Headunit and I've run into some problems.
Now I've got everything working except for the passenger side rear speaker. Problem being is currently I have a dark green a white/black stripe wire (Hilux Loom) that is not attached to anything. Now the left rear speaker wires aren't attached to anything either.
The sterio doesn't get any power, unless I take either the possitive or negative wire for the left over speaker (this is on the head unit's side) and touch either the dark green or white/black stripe wire (Hilux side).
I've looked at a couple of the wiring diagrams on these forums by searching and they've helped me quite a bit but I'm stumpped at the moment. I've used different diagrams from Install Doctor as well to no avail.
Does someone maybe a have a list of all of the wire colours in a Hilux and what exactly they correspond too?
It's a 1991 3l V6 Surf.
Thanks in advance!
Hanré
Thanks in advance!
Hanré
