4WD still not working
    Originally posted by MudSurfer
    That's right! 4WD was working intermittantly.....I'll have to pull the hoses off one by one on the 27th and see what gives......so ignition on will work a bit, but engine on, no vacuum - although Tony did say that with the engine on he could feel the vacuum working fine...and the diff oil is full.......
    lol the plot thickens, helps loads if yer get the full story from the start, lol good luck with it at least youve got plenty to go at from this thread now, keep us updated
      by the top of the front left shock is a multiplug with wires going down to the front diff, have a fiddle with this and clean it or fill it with WD40 or something, if it hasn't already been checked.
      =SOLD UP!=
        Looking from the front or from inside?????????????
          passenger side, in the gap between the block and wheel arch below the fuel filterish sort of area
          =SOLD UP!=
            even on a 3.0????
              Originally posted by joker??
              even on a 3.0????
              well somewhere within a couple of metres of the fuel filter then
              =SOLD UP!=
                even on a 3.0????
                That's what I thought......I cannie see a thing........
                  On the pavement?
                  • #24
                    On the pavement?
                    sussed it, Vince, you are indeed a genius that'll be why it's not working....
                    .....there's bits of loom on the pavement
                    =SOLD UP!=
                    • #25
                      Why do I bother??????
                      I'll have a look for it myself......
                      • #26
                        forgety the $$$$$$t treuck till ytomorrow hahanha
