While at Tony's on Saturday, we had a look at the 4WD and checked a few things, all hoses seem OK, vacuum was working fine - and the relay clicks, the motor works and everything engages (with the ignition power only) now - when the engine is on, all I get is a load of clicks from the relay - and nothing else - no 4WD light (ignition power or engine on).......why??????????????
Tony has disabled the sensor for the diff oil temp too - and that's not made any difference.
