I have a technical query: My 1996 SSRG is fitted with the climate control option. The heating either works full blast delivering hot air, or if I move the control slider just a little to the left, it then chucks out freezing cold air. I could be wrong but don’t think the problem is with the heater matrix as it is delivering plenty of warm air, it just does not seem to be regulating the temperature..... I have followed the instructions on previous threads to clean out the sensor and the sniffer pipe which is located under the dash. It was very clogged but I have very carefully completely cleaned the pipe and sensor then re-installed it. (I didn’t know how to check it electrically though). The various servo motors to control the vents seem to be working fine.
I have run the engine up and still find the problem is there. It seems like other guys have had the same issues with their surfs. Any chance you could let me know if there is something I am missing from my diagnostic checks, I am getting fed up with either freezing or roasting!!
Woodylovestosurf
