When I remove the fuse to 'Dome' then it drops to 30ma. Are the internal lights the only thing on the dome circuit? They definitley go off when they are meant to.
I suppose if I remove not just the bulbs, but the bulb holder-switch module & unplug them. Can't really see what else I can disable to test it. I assume the door courtesy switches provide a passage to earth when they are activated. Unless they have got coroded a bit to allow a 200ma leakage to earth which of course would be insufficient to allow illumination of the bulb.
So its just those two interior lights that run off 'dome' circuit or does that compass thing run off it?
You mentioned a clamp meter, I have one but I have never seen one that will work on DC only on AC. Would be keen to get such a device if you have a make etc.
Thanks
Clive
Thanks
Clive
