Pulling codes on a 3rd Gen?? Possible at home?
  • Pulling codes on a 3rd Gen?? Possible at home?
    Hiya... is it possible to pull codes at home on my 3rd gen without any readers?
    Is it a matter of a paper clip and read the flashes??
    If so where does it go and is there a list of codes? (I tried search)
    Ta.
    More Lift.
    More Tyres.
    More Engine.
    Yup, its all here...
    http://www.hiluxsurf.co.uk/forums/showthread.php?t=62
      Cheers Tony... I opened that page and missed the important bit I was after!!! D'oh!
      Whats more from reading the american forum I read that you can't get codes without a reader so just ordered one... Grrrrrrrrrrr
      Cheers again.
      More Lift.
      More Tyres.
      More Engine.
        Cheers again.
        I don't think I've ever done the codes on a 3rd gen yet, but one of my workshop manuals is for a 99' 1KZ/TE, and covers the paperclip/wire and count the flashes way, and with proper plug in test tools, so I don't think it'll be a problem.
          I bought this book from Rough Traxs, & it has all the flash codes for the
          1KZTE in it.....I haven't had the need to study it yet, but it looks to be all there.
          http://www.toyotahilux.com/?doc=16&cid=265&vid=759
            I don't supose it has anytihng on ABS fault diagnosis does it? more specificly testing the sensors
            Cheers guys...
            More Lift.
            More Tyres.
            More Engine.
              ABS codes are found by joining Tc and E1
              I'll scan the codes and post them in the sticky thread later.
                Cheers Tony... Legend
                More Lift.
                More Tyres.
                More Engine.
                  I found a link, (will post tomorrow its on my work PC) turns out its code 33, so that disturbed wire I mentioned in the other thread is probably it... I just need to find the plug where it goes! I am guessing its the loom under the rear seats... I'll have a look this weekend...
                  Thanks for your help guys
                  Edit:
                  http://www.babcox.com/editorial/ic/ic30121.htm
                  More Lift.
                  More Tyres.
                  More Engine.
