I have a 1996 3rd Gen Hilux Surf. The hazard warning lights come on when the switch is pressed in & it makes the tell-tale sound by the switch but it does not flash, it also does not glow when the main lights are on like the rear window demister switch that is next to it.
So I put a new bulb in the switch & it still doesn't work? My next thought was to replace with a new switch but they are £35. Now thats not cheap especially if it doesn't cure the problem.
It is a bit of a pain when it's dark because you can't see the switch.
Can anyone please advise.
Many Thanks
Regards
Lewis
Many Thanks
Regards
Lewis
