Speed sensor
  • Speed sensor
    Do surfs have a 2 wire or a 3 wire speed sensor?
    2 wire on the 2.4.
      Thanks nev.
      I'm trying to find out if we can use a speedo healer on a surf. Manufacturer needs to know the wiring config.
        So you mean the speedo speed sensor. I thought you wanted the fuel pump sensor. I'll have to check on the speedo.
          Ooops...
            Speedo thingos are available. If I could access the Aussie site I could probably find the info you need but it's been down for a few days and no idea when it will be back. Will have a search elsewhere.
              Here's some info -
              The Hall Effect VSS units can be identified as having 3 wires.
              The Inductive VSS units can be identified as having 2 wires.
              Some Vehicles fitted with 3-wire Hall Effect VSS's are as follows:
              Holden Commodore VN, VP manual and automatic models. VR and VS manual models.
              Rover Land Rover, Range Rover.
              Suzuki Jimny.
              Toyota Land Cruiser, Hilux, 4Runner, Surf.
              Some Vehicles fitted with 2-wire Inductive VSS's are as follows:
              Holden Commodore VR, VS automatic models. VT and VY manual and automatic models.
              Nissan GQ and GU Patrol manual and automatic models.
              http://www.marks4wd.com/products/tyr...orrection.html
                Thanks for that nev.
