Or use an 8mm ratchet spanner!
Rear window dilemma!
=SOLD UP!=
Originally posted by KERRSURFI think I'll epoxy resin it overnight and drill it out for fixings in the morning.
Mark
that is a nice wee tip. this forum is brilliant!
Then, while the motor is out, take the three mounting bolts and hacksaw a small slot in the threaded end. When you come to refit it, you can fit small screwdriver down the bolt hole and screw the bolts back home just leaving a final nip up for the spanner. Speeds up any future removal as well.
Happy window winding!Alan
