Any ideas? i want to fit an electric fuel pump to supply a small veg oil (swirl tank), im more or less copying the aus guy, he's useing a small tank made of
110mm soil pipe with a screw cap on top and cap glued on the bottom, he feeds oil to this via an electric fuel pump and controlls it by two reed switches and a corolla break fluid level magnetic float, however he hase'nt gone into detail wireing wise, so!! how can i controll the level? one reed to switch it on and one to switch it off, but as far as i can see as soon as the float rises above the reed switch the pump will stop, from his pic's he's useing a circuit board he's made, but this may be beyond me, any other way of controlling the level, say with relays etc, i'm lost on this,
