My wife's batteries were on the way out and sometimes would not start. Whilst trying to jump start it the rev counter reacted by swinging across the dial at great speed and eventually jumped the zero stop
This meant that when the engine was off it hung vertically and when the engine was running it swung upwards only to be stopped by the underside of the zero stop pin.
The way I was able to put the needle on the top side of the pin, where it belonged, was as follows:
1) Remove the rubber grommet that is normally removed to re-set the T-Belt light.
2) Get a longish, stiffish but flexible piece of wire (straightened out paper clip) and put a small oval shaped loop in one end. The loop must be small enough to pass through the hole in the dash perspex but large enough to go over the end of the rev counter needle. You can probably guess the rest but...
3) Pass the loop end of the wire through the perspex hole and manouvre until you can pass the end of the needle into the loop.
4) Slowly push the needle up until it touches the underside of the stop pin.
5) Using a 'twist and push' motion, manouvre the needle passed the pin.
6) Release the wire loop from the end of the needle and extract it. Re-fit rubber bung into perspex hole. JOB DONE
The trick is to get a stiffish piece of wire, of the correct length, that still can be curved readily.
Hope this helps
This meant that when the engine was off it hung vertically and when the engine was running it swung upwards only to be stopped by the underside of the zero stop pin.The way I was able to put the needle on the top side of the pin, where it belonged, was as follows:
Hope this helps
