Engine Radiator/Condensor Electric Fan Motor
  • Engine Radiator/Condensor Electric Fan Motor
    Hi if the aircon motor is gone is it ok to rip out this fan and rad?
    He who dies wit the most toys WINS!
    Do you mean the one at the bottom where the sump guard is & has 2 fans mounted on it??
    if you do you can but might need to de-pressureise the system first, aparently that stuff can be cold if dumped overboard onto your hands.
    Mine had no gas left in in so just removed the rad & fans and tied the pipes out of the way
      Do you mean the compressor at the top driven by a belt? If there's no gas in the system then yes, rip it all out, including the hoses, rad and twin fans behind the bash plate.
        As Vince says - Rip all of it out. Less load on the engine and less weight on the car. Done mine ages ago. If it gets hot in the summer I open a window!
        So now I get at least 50mpg and the truck does 0 - 60 in under 5 seconds and tops out at 149mph.
        Honest.
          cheers, i actually ripped it out last nite doin my belts but taught i'd better check! ha
          there defo is an increase in power but not hugely! how'd ya get urs to do top speed of 149mph boyo???
            same way he gets 50 mpg
            Non intercooled nothing.
              and that is................
                http://www.youtube.com/watch?v=NzlG28B-R8Y
                  Tushea!
                    By visiting fantasy land where the weather is always sunny and its all made of chocolate.
                    Without Surf And Unhappy
