I've had a good look thru all the threads relating to the tailgate, but none seem to have the same problem as me so here goes..................
The rear window goes up and down fine (especially as it's all just been greased, thanks to another thread) BUT only from the interior switch..
When i use the key in the tailgate i get absolutely no response in either direction.
Removed the door card yesterday and had a look, but found nothing wrong!
Having read other threads on the rear door, my first question is...
Are there seperate UP / DOWN relays (on the soldered PCB) for the switch and the key or should i assume that as the switch works every time that the relay is fine, if so what next????
Thanks in advance!!!!!
Alan
Alan
