What the hell is this?
  • What the hell is this?
    Whilst troubleshooting my turbo I came across an electrical thingy mounted just in front of the rad below and to the left of the A/C condensor. It's grey in colour about 50mmx10mmx10mm with a spade connector at each end and a wire attached to each connector which feed into the loom. What is it? Anyone know? I ask as both the spade connectors on mine have rotted through and hence not connected and I wonder if it has anything to do with other problems I have with my surf???
    Pete
    Life is not a dress rehearsal
    1996 3.0 SSR-G 5-speed
    (Auto's are for the indecisive!!)
    Need pictures!!!
      Originally posted by rich
      Need pictures!!!
      On their way, jus lemme get that damned grill off!!
        ere's the pic you aksed for
        The a/c radiator(front mounted) is at the top of the pic and thats the condensor inlet/outlet on the right handside, you can clearly see where the terminals have snapped off on the thingy which is immiediately to the right of the condensor!
        Pete
          thingy
          Pete
          Hi l have only found these on the 3.0litre T/D up to now and they seem to let the electric fan turn slowly for some reason. Thats all l know .
          Live Life To The Full
            Hi Bob
            If this slows the operation of the fan then it would be a Resistor.Will have to see if my 2.4 has one.
            Neville
              my 1990 2.4 td has the very same thing, complete with broken terminals, i never have found out what its for but would like to know.
              baz
                I'll have a look at mine tomorrow because my electric fan has never kicked in even while offroading in a heatwave.
                It's only a hobby!
                  Pete
                  that could have been for the fog or spot lights, are there any fitted or have there been
                  [size=5][/size]
                    Yep that was going to be my answer. I dont think Mr Toyota would put anything electrical in the full flow of water. check to see if the two wires go into the loom or they have been taped neatly to the out side for rigidity. Cant see the reason for putting some thing like that so far forward.
                    Geoff.
                    Rubblebags (Geoff).
                      it is a resistor that feeds the fan which runs at a slow speed when the temp gets high and when you switch your a/c on a feed by passes the resistor and the fan spins at full speed hope that helps
                        Yeah , that makes sense . The reason for mounting on the rad is possibly using the rad as a heatsink as resistors get very hot . Hotter then the rad .
                        Some cars have these resistors as 'dim dip' units when you turn your ignition off with the headlamps still turned on it dips your headlamps down to a dim level .
                        Rick
                          Before the Surf I had a swb Landcruiser with a similar resistor for the dim-dip headlamps that come on with the side-lights when the engine is running.Its fitted up front for the cooling needed because it gets very hot very quick.Most of the Fords had them from the mid eighties and they used to rot the terminals just like whats happened to yours.
                          Don`t get mad,get even !
                            Cheers for the answers chaps, I can sleep at night now!!
                              uh oh
                              i own a 2.4 td mine also has this broken thing infront of the radiaitor so come on guys wtf is it somebody must know...ive been told it may step down the voltage of something a resistor of some kind? who know's what it really is please let us all know
