1990 2LT-E. I have unplugged the Air Temp Sensor as the Surf was smoking a wee bit. Does not smoke now, but should I get a new sensor, or just run without it? Thanks.
Unplugged the Air Temp Sensor
Hi Murray, What colour is the smoke? I just read your post about possible oil in the water, and I am wondering if the 2 could be connected?Originally posted by Muzz671990 2LT-E. I have unplugged the Air Temp Sensor as the Surf was smoking a wee bit. Does not smoke now, but should I get a new sensor, or just run without it? Thanks.
Pete
Even though mine is a 2LT not the E model I am sure all is pretty similar
Which one is the air-temp sensor that you disconnected?
I would be keen to give it a go myself
Pictures please or a good desrciption.
Mine does the "manouvering under smoke" thing like a Challenger tank on take off but runs fairly clean during normal driving.
I am keen as mustard to try ANYTHING to reduce this black cloud effect.Simon.O.
'90 SSR Ltd 2.4TD 5 spd
SimonOriginally posted by simonoEven though mine is a 2LT not the E model I am sure all is pretty similar
It's on the air filter housing.The top part where the elbow is.
Neville
