the engine warnin light keeps comin on and goin off but wen it's on the turbo don't work! the rev's also bounce wen it's idle! does any1 no wat it is or wat it cud be! i've just serviced it change airfilt, oil filter +oil, diesel filter! thanks
engine warning light?
I had the same problem intermitantly. I reset the ECU by disconnecting the batteries for 20 minutes. After this it was OK.Originally posted by shawlynotit did it b4 hand, thts y i serviced it, the light cums on wen it get warm don't no if tht cud mean ought
If this dont work the next time it does it check the fault code. check them here
http://www.off-road.com/toyota/tech/codes/index.html
hope this helpsTrust your Hound.
