I`m looking for some advice.
I want to install about 10 led bulbs to a switch on the dash I have some white led’s in holders with the resistor built in. I also have an illuminated rocker switch with three connection terminals on the rear.
The front spots are wired to a switch close by they only work when the side lights are on and the switch is on. I would like the led’s to work in the same way. could I just run a spur off the spot’s for the side light connection and the earth then with the third connection run that to the led’s. then just run an earth to the black on each led.
Do I need to install a fuse anywhere if so what amp should it be? And last of all how should the 3 terminals be wired on the switch?
I had a little go today I’m no expert on auto wiring and ended up blowing the 20amp fuse on the side lights!!!
However, if you try trial and error, it's better to start low and work up rather than vice versa. That way, if you have a fault, you have less chance of damaging something.
looks like some of the pic's have dissapeared, i'll sort some out tonight,
