"It" is, I think, a resistor. It is mounted at the bottom right hand corner of the air con radiator as seen from the front of the car. In my case both wires have corroded away. A nearby connector (with the outgoing wires cut off) coming out of the wiring loom has a black wire and a red one with a black tracer.
I've only had the car a few weeks, so still getting to know it, however everything seems to work except the air con. So, what's it for, and if I replace it will the air con work??
Thanks,
Gordon
Thanks,
Gordon
