How are they supposed to work on a 2nd gen? My driver's switch is a two stage switch, but you can't use it manually, only one-shot. So to put window down half-way, you push switch fully down to drop the window, then flick it up to the half postion to stop. This doesn't work when bringing the window up, so if you have an open window and want to half-close it, you have a right fiddle to do it.
Dave
					Dave
