Imobiliser kills truck
  • Imobiliser kills truck
    Hi All,
    I just got a new alarm/imob. fob for the Sub, and took ages trying to re-program the system yesterday lunch time*. At going home time, It wouldnt start due to virtually flat batteries. had to get a jump.
    Is this normal?
    When I went on hols last year, I got back to the airport to find a flat battery, didnt think of the alarm as the cause - perhaps it sucks life from batteries.
    I might get a battery isolator so I can have one battery isolated if I go away, thus being able to start her up when I return.
    Anyone else had this problem?
    * My system wouldnt re-set because: Alarm info said to turn ignition key one place to dash lights, turn back one place, repeat to enter numbers. HOWEVER the Sub is a 2 click turn to get dash lights, so I did that, turn to dash lights, turn back one, turn to dash lights, turn back one etc. HOWEVER it seems you need to turn to dash lights, turn back to FULLY OFF, turn to dash lights etc.....
    if the alarm's pulling that much off the battery there's something wrong with it. Do you have a meter to check the current draw off each battery with the alarm on/off?
    =SOLD UP!=
      yeah, good point, I will look at it this weekend.
      Someone told me that alarm/imobs drain batteries regularly, but that seems a LOT of suck on a big battery just to go beep if a cat sits on the roof...
      Batteries prob. need changing too, I think one is down and pulling the 2nd down with it.
        Originally posted by legendgamesmaster
        had to get a jump.
        Is this normal?
        Not after the baby's born mate!
          just got back from15 days in the USA motor outside at heathrow, plenty in the batteries, reccon yours are on the way
          Tony
